DJI Grace
Flight distance : 405039 ft
Hecate Posted at 2017-12-7 12:33
Thank you DJI grace, let me add some more info....
For White balance correction, sample a color on the jpg with the color sampler that is around 30% grey, in the jpg below I used the light grey wall on the bottom right(used your green tinted jpgfor this), If there is no light grey try and find a black area. If you are new to lightroom, I clicked on auto correction and reset the exposure slider back to zero (my lazy way to correct shadows, highlights and contrast).
The difference between raw and jpg is 2 f-stops of shadow recovery (4 stops recovery for raw and 2 stops for jpg), and 1 f-stop recovery for highlights when using raw and zero highlight recovery for jpg, so it is important to expose for the sky when shooting jpg as too bright areas cannot be corrected. So when shooting AEB and merging the three jpg shots in lightroom or any other image processor it will be the same as raw, 4 f-stop shadow recovery and 1 stop recovery for highlights, however; using DXO software one would be able to recover 6 stops of shadow recovery, it is also possible to run lightroom in the 2003 process and try a 6 stop recovery, it has its problems but can be corrected with other software.
impressive!!!
Thank you for sharing this to us! |
