Cetacean
Flight distance : 2528264 ft
Aloha Harsha,
Sorry to hear about your crash. Good you got it where it may be just calibration issues now. Your video did not play for some reason. It would be helpful if you can fix that. Do you use YouTube. YouTube is very reliable.
One thing you can try while you work on the video problem is to do more calibrations and tests. But, this time do them in pairs and change the order. Do the IMU first followed by the gimbal and test it, then if that did not work, do the gimbal first followed by the IMU and test it.
If you are lucky, the repeated calibrations will correct the deviation of the gimbal and camera until they get more centered. Changing the order of the calibrations helps in that process, little by little. If it improves at all, it is working. If not, try another approach.
Are you getting a live view OK? Are there any other issues?
Hope this helps!
Aloha and Drone On! |
