Shure MV88
5003 6 2017-12-6
James Davey
Do any of DJi's gimbals permit the use of a lighting adaptor connected, Shure MV88, microphone?
I have an iPhone X with this great external microphone and want to buy one of these products but not sure I will be able to use this mic.
Thanks in advance
2017-12-6
Hi, James, thanks for the interest to DJI products.
For Osmo Mobile, please note gimbal balancing is very important, if you mount iPhone X, there will be no room to attach external microphone.
For other models, like Osmo, Osmo+, Osmo Pro/RAW, the audio is recorded by internal audio board, you can also attach external mic, but we recommend to use the mic in our compatible list for better experience:
Sennheiser MKE400
Sony ECM DS70P
Rode VideoMic Pro
Rode VideoMicro
Mymyk Smartmyk
DED DV-889
2017-12-7
AJA222
DJI Mindy Posted at 2017-12-7 03:15
Is there enough room for a Shure MV88 if used with an iPhone 7? I've seen a Rode Video Micro being used with an Osmo mobile & an iPhone 7 but you then need an adapter and a cable. I have a counterweight.
2017-12-9
AJA222 Posted at 2017-12-9 03:29
Sorry Sir, we have no official suggestion about how to mount the external mic to Osmo Mobile, maybe other users could give you some advice.
2017-12-10
Drone Mood
Hi James ! Did you find a solution ?
2018-5-21
djiuser_2ikM3EiucPkQ
I have a 13 pro max with a mv88 mic will the new om5 accommodate that?
Niki
2022-3-14
djiuser_2ikM3EiucPkQ Posted at 3-14 13:39
Niki
Hi there, iPhone 13 Pro Max is compatible with DJI OM 5. The external microphone cannot connect to the DJI OM 5 directly. But there is no limitation of the software or hardware in the OM 5. So this function depends on the compatibility of your mobile phone and the microphone. For more details, please refer to: https://terra-1-g.djicdn.com/851 ... tibility%20List.pdf
2022-3-19
