TheMann58
Flight distance : 18669501 ft
First, the good news - your gimbal tilt motor appears to be functioning as the camera swings all the way up and then all the way down immediately after turning P4Pro battery on. If the camera gimbal motor was burned out, this would not happen.
However, at the end of startup sequence the camera should pop up to straight ahead (0 degree) position. This is NOT happening. You also note that you cannot change the camera gimbal position with the wheel on the back left side of Remote Controller (RC).
Here are my suggestions for trouble-shooting and, hopefully, fixing your unresponsive gimbal.
1) STEP 1 - Perform a RC stick calibration, which will recalibrate and re-zero the default center-point positions of both the left and right control stick AND the gimbal control wheel. It could be your issue is caused by the zero position of the gimbal wheel not being correctly set. This can sometimes happen after a firmware update OR, possibly, you recently calibrated the left and right RC sticks but forgot to calibrate the gimbal thumb wheel, which could render the gimbal wheel functionally useless.
To calibrate the RC sticks and thumbwheel on your RC:
a) attach your mobile device to the RC as usual
b) power on the mobile device
c) turn on power to your RC (but do NOT power up the P4P aircraft - it must remain OFF during the stick calibration)
d) Start the DJI GO 4 app and get into camera view, which will show a black live video image because P4P is not powered on.
e) Tap on 3 dots in upper right of screen to enter General Settings
f) Tap on the RC symbol at left of General Settings screen (third symbol down)
g) Tap on Remote Controller Calibration at top of Remote Controller Settings screen
h) Follow instructions on screen and calibrate both RC sticks and the thumb wheel, by first moving each stick to one corner and then moving the stick to each of the other three corners slowly in succession
i) Then (and this is the important step) slowly roll the gimbal wheel all the way to the left roll position limit and then all the way to the right roll position limit SLOWLY and do this at least three times. This is the step that should correctly reset the zero gimbal position on your gimbal wheel. When you release the thumbwheel after this step, the graphic on screen should show the gimbal wheel is at its correct mid-point position.
j) Now, turn everything OFF (except the mobile device) and exit the DJI Go 4 app. Then power up the RC, then power up the P4P and then start the DJI go app. If this worked. the camera gimbal should go all the way up, then all the way down and then pop up to horizontal (straight-ahead) position shortly after powering on your P4P.
STEP 2) If the RC calibration in STEP 1) does not FIX your gimbal control wheel issue, then I would suggest refreshing the firmware on your P4P using the DJI Assistant 2 app. Do this even if you already have the current firmware installed. Something may have gotten corrupted in the firmware on your P4P.
After firmware is refreshed, try the gimbal calibration procedure in STEP 1 again.
