Electro-Nick
Flight distance : 7083891 ft
Mindy & Electra, epicjib is correct and you effectively have a bug in the DJIgo4 software. With the last few updates to Go4 It is possible for the SSD recording to be enabled, but to not have an SSD card installed. When that happens, it is impossible to change the SSD slider from enabled to disabled because the slider itself is disabled - you have to insert an SSD card in order to enable the slider to turn off the SSD recording.
If you don't have an SSD card, then that is a problem because you cannot disable the SSD. If you cannot disable the SSD, then you cannot use the old colour modes, just-cinelike and normal, or d-log in EI mode.
Now the biggest problem seems to be that the recent updates to Go4 enable the SSD by default, even where no ssd is present. That now means that people who do not have an ssd and have previously been using the different colour modes are trapped and can only use dlog, cinelike and normal.
Please do the following to replicate the problem...
Install latest firmware and version of DJI Go 4
Turn on inspire 2, do not insert a Cinessd card.
Start Go4 and check your video recording settings, the SSD Is most likely enabled.
If it is enabled, try to turn it off... you can't
If the ssd is not enabled, then repeat the above and install a cinessd card
Now enable the cinessd
Turn off Go 4 and the inspire and remove the cinessd
Turn everything on again
Try to disable the cinessd... you can't.
If the cinessd is enabled, you cannot select colormodes other than dlog, normal and cinelike.
