Turn11.Larry
DJI Thor Posted at 2017-12-7 19:17
Hi Larry, if you only need to check the menu, you can connect the drone, RC and app together, then go to the app and go through all the pages without taking off the drone; you can also try to connect the drone to a PC and launch the simulator on DJI Assistant 2.
But if you need to fly the drone in NFZ, you can contact to unlock it. Generally, please kindly follow the NFZ regulations and maintain the safety of flight.
Thank you Thor. I am only interested in getting the major calibration completed. I am approximately 1 mile perpendicular to the runway. As I mentioned I am a kite flier and have to follow most of the same safety guidelines drones have to follow. To get to a safe flying area (RC planes flying area the city has built) is a bit over 10 miles drive.
There is an Android app B4UFly that will pretty well give you guidance on where you can fly.
ALL I want to do is be able to get everything setup so when I go to the RC field I have a high degree of confidence there will be only minor refinements to setup. Yesterday I thought I had adequately prepared my Mavic and I drove over to the field and all of a sudden the controller said it needed to be calibrated. I thought I was following directions but it would not calibrate.
That is all I want to do in my back yard is get it setup, learn where the controls are and how to access them.
Thanks again for your direction.
Larry |
