Version 4.1.18; Is it safe yet?
1098 10 2017-12-7
mtnlandpix
I have seen a lot of negative threads regarding DJI GO 4 V. 4.1.18.  I use a iPhone SE with my Spark, but have not upgraded to the new version yet.  Should I just keep using the older version, or has anyone had success with 4.1.18?
2017-12-7
VicGenesis
I recently had to downgrade from the newest firmware to the 4.1.15 so that I could use the OTG cable with my Galaxy Tab A.  Waiting to see if someone updates and says it's working.
2017-12-7
Javey
Flight distance : 503458 ft
Mine crash landed on the new version and has had frequent video link problems so I’d wait. I never had any problems before.
2017-12-7
lannes
Flight distance : 4465 ft
Javey Posted at 2017-12-7 12:59
Have you upgraded to IOS 11.2, I was having problems with 4.1.18 and 11.1.2
2017-12-7
Javey
lannes Posted at 2017-12-7 13:00
Yes it all happened with 11.2
2017-12-7
dansmar
Flight distance : 422149 ft
I was having issues with iOS 11.1.2 but since upgrading to 11.2 DJI 4.1.18 seems ok both for otg and wifi.
I also use Android, that I had to downgrade to 4.1.15 as the newer version was unstable for me and broke otg support
2017-12-7
DJI Elektra
Hi, sir. What is the system of your IOS device? If you use 4.1.18 and the app crashes, please upgrade the system to 11.2 and reinstall the app. The bad performance may be caused by the IOS system. Thanks for your cooperation.
2017-12-7
Jos A
Flight distance : 73209 ft
Can you confirm DJI Elektra that DJI is working on to fix 4.1.1.18??
2017-12-8
fans11080e2b
Flight distance : 1138 ft
Switzerland
I just returned from a weeks holiday in Malta where I experienced constant Go4 App crashes for the first time...giving me serveral heart attacks...It seems my IPad updated either the IOS or the Go4 App without me noticing it... After some Google checking I updated IOS to 11.2 and reinstalled Go4 4.1.18... problem solved, works fine with OTG cable or without...FYI
2017-12-8
Dan O
Flight distance : 650768 ft
Romania
Now, this 4.1.18 is a shame. It looks like DJI only focused on blocking OTG and FCC hack in Europe, which I believe needs to be done but not be destroying the reliability of the apk. Of course I do stay on older version.
2017-12-8
Jos A
Its a week later and still 4.1.18 is not fixed. If you are not on the Forum and buy a Spark you can loose your Spark in a moment.
2017-12-9
