Mike9129
Flight distance : 4112812 ft
Will you be using it for mainly photos or video work?
theres practically nothing between the quality of stills ive gotten out of the inspire 1 x5 compared to the inspire 2 x5s
as for video, the inspire 2 wins by quite a lot. even without the prores/cindng licence, the standard video is quite a bit better, and you have farm more options for frame rates (inspire 1 is locked to 24/30fps 4k, and 50fps 1080p, the inspire 2 x5s goes to 60fps 4k and 120fps 1080p). That being said, if your only using the video feature for inspection instead of commercial video production, the inspire 1 will be plenty good.
if your looking to do just inspection work, you're going to want to get the x5 or x5s, not the x3 or x4 cameras. the reason being is you can swap the lens for something with far more zoom so you wont need to get as close to whatever it is your inspecting.
its probably also worth considering that, to the best of my knowledge, only the inspire 1 supports integrated thermal cameras at this point, might be something of relevance to you. |
