IMU Calib. Failure: ACC1 Disconnected
4101 10 2017-12-7
Thorpapa
Flight distance : 543563 ft
South Korea
Phantom 4 Pro+.
IMU calibration passed but Calibration Error comes back.
Various tryings(restoring to factory defaults and re-installing the firmware)  have no use at all.
One thing what I figure out is that the IMU ERROR is closely related with the TEMPERATURE of the drone.
Following photos explain that....
1) Normal condition after COLD start.
2) IMU error(ACC1 data error) after 2~3 minutes. Period depends on ambient temp.
3) IMU error(ACC1 and GYRO1 disconnected) after 4~5 minutes. The period becomes shorter as the ambient temperature becomes higher.
I've got SAME results for several experiments except the period  mentioned above.
Photo 1: Normal
Normal
Normal
Photo 2: ACC1 Data Error
Data error
Data error
Photo 3: ACC1, GYRO1 disconnected
Any advice would be greatly appreciated.
2017-12-7
DJI Diana
Flight distance : 2408 ft
Hi Thor, may I know when did this issue start? Did anything happen before? What is the current firmware version of the drone? Could you please provide a screenshot of the "About" page?
2017-12-7
Thorpapa
South Korea
DJI Diana Posted at 2017-12-7 22:19
I got p4p 3 weeks ago and flew it 3 times without any problem.
Last week, after update, I've got this problem. Thus, I tried all thing guided with DJI chatting aids.
Finally, I made an appoint for AS.
2017-12-7
Thorpapa
South Korea
Firmware Version should be newest one, RC: 01.02.02.00, AC: 01.04.0602
2017-12-7
Thorpapa
South Korea
Thorpapa Posted at 2017-12-7 22:36
2017-12-7
DJI Diana
Thank you for the info, I've forwarded it to the engineers for a check, I'll let you know once I got a response from them.
2017-12-8
DJI Diana
Hi, Thor, just got a response from the engineers, we need more data for further analysis, could you please export the flight data of the drone via DJI Assistant 2, then upload them to the Dropbox? So I can download it for further analysis.
2017-12-11
Thorpapa
South Korea
DJI Diana Posted at 2017-12-11 20:32
I have changed mc at the service center in Korea. They sad the IMU sensor was bad.
Now, new mc is fine. I donot understand why this kind of malfunction has not screend in QC before sale.
Thanks anyway, Diana.
2018-1-1
DJI Diana
Thorpapa Posted at 2018-1-1 23:19
Sorry for the trouble you have been caused. It is so glad to hear that it is fine now, hope you can enjoy it, should you have any question, please feel free to contact us.
2018-1-2
Serhan Aslan
Turkey
I've had an accident and the gimbal cables with the right leg in the back are broken. I changed the gimbal cables. The camera image comes up and the gimbal works on first boot. however, the system gives some bugs and the gimbal does not take action from the controller. IMU indicates the sensor is not connected( IMU disconnected!).What can I do about this problem? Based on your experience, I look forward to your support and assistance.
Thank you.
2019-10-29
Serhan Aslan
Turkey
2019-10-29
