Wifi not visible after Firmware upgrade
569 3 2017-12-8
djiuser_laPcJlk
South Africa
After i updated the firmware the Wifi is no longer available, I have reset the wifi, i have tunred the wifi on and off... still nothing. Logged a call with DJI support yesterday and still nothing.
2017-12-8
Hi there, sorry to hear that. Did you reset the WIFI successfully?
When you keep pressing the Trigger and Shutter button and Power switch, did the right indicator become solid green before you released them?
If the the process is correct, please try to flash the firmware again according to the following video:
Please let us know if it helps.
2017-12-8
djiuser_laPcJlk
South Africa
Good day
This also did not work, the update keeps failing.
Thank you
2017-12-19
djiuser_laPcJlk
South Africa
if i buy a new handle will this resolve the problem?
2017-12-20
