DJI Thor
Flight distance : 13602 ft
Hi sir, may I know the mobile device you are using? For the transmission issue, please try to reinstall the app, and check if the transmission signal bar is blinking or empty, also, please take a look at the Image Transmission Settings (the HD icon on the top right of the camera view), is it green or red of the noise at current channel? If it is red, please choose a stable channel to avoid the interference. Then please try to switch the phone to Airplane Mode for testing. Besides, had you tried another phone to test this problem? Please try another mobile device if it is possible.
For the disconnect, please check if it is the app disconnect or drone disconnect. It would be nice if you can upload the video you mentioned in 2# to Dropbox so I can check the details about it. Thank you. |
