What sd cards are you guys using?
2261 26 2017-12-8
Koia Koia
Flight distance : 772867 ft
I'm looking to buy a 64gb SD card for my mavic. With all the options out there I wanted to know if any were better then any others.
Koia
2017-12-8
Time2Party
Flight distance : 169314 ft
Belgium
I use a Sandisk Extreme SDXC UHS-1 card from 64gb.
2017-12-8
CycleParadise
Flight distance : 385338 ft
I have a Sandisk Extreme 64GB  microSDXC UHS-I in the aircraft.
I bought two Sandisk Ultra 64GB  microSDXC UHS-I but haven't tried them yet.
2017-12-8
Hellsgate
Flight distance : 1991555 ft
I think you will find that the sandisk extreme is the most widely used sd card.
I think the main reason being its a lot easier to obtain than some of the others that are suitable
2017-12-8
Snipes_Blaster
Flight distance : 510217 ft
How many Samsung Evo Plus? any good?
2017-12-8
rolling56
Flight distance : 138310 ft
These were $13.99 black friday and i got 2 of them. One for each of my Mavic's. They come with adapters too. https://www.amazon.com/gp/produc ... 0_s00?ie=UTF8&psc=1
2017-12-8
Caspers driver
Flight distance : 4540515 ft
I'm using both 16 and 64GB Ultra sandisk. Work great in mavic and P3S   Paid $9 something for both sizes at amazon. (Lucky moment with 64GB ;)
2017-12-8
M.C. Pilot
Flight distance : 10278435 ft
Def recommend the Sandisk Extreme. Superb quick downloading card.
2017-12-8
Silver Surfer
Flight distance : 46283 ft
Hi Koia Koia, I use a SanDisk Extreme PLUS 64GB micro SDXC UHS-I/U3 Card.  It's very fast and works extremely well with my MPP.  I got mine at Best Buy for $21.00.
I wanted to get a 128GB, however I checked with DJI support and they informed me that the Mavic Pro Platinum will only take 68GB....  It will not take anything higher.
2017-12-8
DJI Thor
Flight distance : 13602 ft
Hi Koia, just for the specs reference, we suggest using SD card with Class 10/UHS-1 and above and writing speed equal or higher than 60Mbps. Please kindly choose original SD card from the SD card company, which can ensure the full test of its stability and compatibility.
2017-12-9
onlytwo
My Mavic Pro is amphibien , I take the video  the same time with Mavic Pro Camera  ON the water and Camera360° UNDER water , So  I used SD 128Go
2017-12-9
CycleParadise
rolling56 Posted at 2017-12-8 16:52
Yup!! That's the deal I got too!
I was worried that the Ultra might not work. I haven't had a chance to try it yet. I'm glad to hear it does work.
2017-12-9
CycleParadise
onlytwo Posted at 2017-12-9 00:34
[view_image]
Holy cow!!! That's quite a set up. Not sure I'd be that trusting!
2017-12-9
djiuser_MP6tU5Q
128GB Samsung evo card I got off amazon for $44. says does up to 85MB/Sec and using my usb 3.0 reader I found writing speeds are sustainable at 55MB/Sec and reading about the same.  I even verified it as 128GB.  Shocked.
I also have a 64GB sandisk card that in my reader does 70MB/sec writing sustained and peaks up to 81MB/sec sustained reading
And the included 16GB sandisk card...
2017-12-9
SupaMonkey
South Africa
I got the SanDisk 64GB Extreme Pro. Wanted to try the Samsung but no availability when I was buying.
2017-12-9
MARSAN
Flight distance : 966978 ft
Belgium
Try to get something like the SanDisk Extreme U3 (the letter U with a 3 inside it).
Don't be blinded by the astronomic read speeds on SD cards, it's the write speed that matters and I'd recommend a minimum write speed of 30 MB/s (megabytes per second), if you want to record 4K video clips.
2017-12-9
Koia Koia
Ended up with a Sandisk Extreme Pro 64gb.  The temp proof shock proof x-ray proof stuff seemed of some value.  Probably keep my eye out for some cheap extras just in case but I'm thinking 64 gb out to be plenty.
2017-12-9
Koia Koia
[view_image]
Im confused by this picture.  That's some impressive modification.  What's your flight time like with all that extra weight?
2017-12-9
A CW
Flight distance : 13877205 ft
Sandisk extreme pro A1 U3 and Sandisk extreme U3. Use the pro when setting out to film 4K or 1080p @ 60p as the read/write speed is quicker though the non pro is good enough.
2017-12-9
bernardren07
Flight distance : 48504 ft
Singapore
MOST i use sandisk extreme pro 64gb (A1) or samsung pro plus too
2017-12-9
'BushCrapper.IndianChief'
Flight distance : 61335 ft
Delkin 128GB 1900x micro SDXC UHS-II Memory Card... is the fastest around by far, with a ‘LIFE TIME GUARANTEE’..!
2018-3-20
Delkin 128GB 1900x micro SDXC UHS-II Memory Card... is a ‘CLASS 10’ the fastest around by far, used by professionals and comes with a ‘LIFE TIME GUARANTEE’..! “If you buy quality, you buy once. If you buy cheap, you buy twice”..!
2018-3-20
dwainwayne28
Flight distance : 583323 ft
Trinidad and Tobago
I use both Sandisk and Samsung evo 64gb SD. They both work well!
2018-3-21
AdventureCamp
I use the kingston 100mb/s
2018-3-21
rikk08
Flight distance : 21877946 ft
Malta
The ones that came with the mavic are surprisingly pretty good, I've got a whole heap of Sandisk sd cards that I use for mavic+ audio recorders and I've never had a problem recording in 4K.
2018-3-21
IceBox-Murdock
Flight distance : 43845 ft
I use SanDisk - Extreme PLUS 64GB microSDXC UHS-I Memory Card. I have 2 of these just in case.
2018-3-21
M2Wair
Flight distance : 1192231 ft
Sandisk extreme pro A1 U3 for all AC  and have 2 x Samsung 64's as back ups
2018-3-21
