Jenee 2
Flight distance : 7852129 ft
Whenever you update the Mavic, you also have to update the RC. On some occasions you will also have to update the batteries.
Update your RC through the Assistant 2 software and then turn everything on. If you are still getting the firmware message then it may be related to the battery. If it is the battery, you can do that over wifi if your phone is currently in a wifi area. The battery update is only small and does not take too long.
You can also do the battery updates by connecting the Mavic via Assistant 2.
You will need to put each battery into the Mavic for the update. |
