Crystalsky CPU specs
5765 10 2017-12-9
dan_vector
Flight distance : 613753 ft
Oman
hi all. Does anyone know what the CPU spec is on the crystalsky models? The online specs don’t provide this data.
2017-12-9
StianGel
Flight distance : 686654 ft
Norway
According to CPU-Z, my 5.5" has a Rockchip RK3066 4-core CPU @1.61GHz with a Mali-T760 GPU
2017-12-9
dan_vector
StianGel Posted at 2017-12-9 18:32
Thanks very much!
2017-12-10
castormalin
Flight distance : 638911 ft
Interesting info. Thank you very much !
2017-12-10
Hello, guys, I will help to verify if StianGel's post about CPU is correct, will come back to you soon.
2017-12-10
Hi, Dan, sorry to have kept you waiting, unfortunately, after confirming with our engineers, the CPU info cannot be provided, therefore, I cannot verify if StianGel's post is right, sorry for the inconvenience.
2017-12-13
wreyniers
Flight distance : 1501355 ft
Hello StianGel, I believe this to be incorrect after doing a bit more digging. CPU-Z does report that we have a Rockchip RK3066 processor but this is incorrect.
- The RK3066 is a dual-core processor, the CS has a quad-core.
- The RK3066 is a very weak processor - it scores 1,602 on PassMark Android tests: https://www.androidbenchmark.net/phone.php?phone=Rockchip+rk3066
- When I run a PassMark on the CS it displays the following CPU data:
  • Processor: ARMv7 Processor rev 1(v7l)
  • Hardware: Rockchip RK3288
  • Num cores: 4
  • Core 0 - 3 Range: 126Mhz - 1608Mhz
- With the CS I get a PassMark score of 4,907, which is a little above average for the rk3288 but within reason: https://www.androidbenchmark.net/phone.php?phone=Rockchip+rk3288
Also, it looks like Rockchip themselves announced the CrystalSky as having their RK3288 chip. See: https://www.facebook.com/rockchi ... d-/586348574891730/
I was really surprised to see CPU-Z displaying bad CPU info as that has been my go-to tool for this kind of thing. I got suspicious when I looked up the RK3066 processor and saw how slow that chip is.  Luckily we got the much faster RK3288.
BTW, here's a wikipedia article describing the RK3288. Specs line up with advertised capabilities.
That said, even though DJI and Rockchip advertise H.265 4K decoding, this is not currently working on CS using untouched video files captured my the DJI Mavic 2 Pro.
2018-11-1
HedgeTrimmer
This Thread might give you an idea of Crystalsky's performance.
Want idea as to how your SmartDevice ranks?
Crystalsky Ultra's performance appears to be below: Huawei P8 Max & Samsung S5, and above iPhone 6 & iPhone 5s.
Although, from my experience with both Crystalsky Ultra and iPhone 5s, the iPhone 5s running iOS vs. Android seems to be slightly better at handling loads of GO-4.
2018-11-4
Sweflyer
Flight distance : 14066975 ft
Sweden
wreyniers Posted at 11-1 11:10
Thanks for your insights.Any idea as to why the CS cannot playback H.265 4K?
2018-12-4
Sky Donkey
Flight distance : 355157 ft
well below whats really needed.
2018-12-4
nixuspix
Flight distance : 2864974 ft
Latvia
"CPU info cannot be provided" - what a strange answer from DJI engineers. What is the reason for this top secrecy?
2018-12-4
