DroneFlying
Flight distance : 10774613 ft
crashcore Posted at 2017-12-9 13:02
If by barely above the water you mean several feet, yes. Like I mentioned, after having done this shot several times earlier, this is the first time it behaved like that.
Good point about the care refresh. Not sure I have that so if I don't, probably going to need a total replacement. Too bad, since it still flies fine. DJI support will probably tell me what to do in a couple days.
Looking at the video starting around 0:30 -- especially at around 0:32 -- it's clearly much closer than that as it's flying forward.
If you'd like to provide a link to the TXT file (log from you mobile device) on PhantomHelp I'll take a look. An even better record of what happened can be found on the DAT file, and if you retrieve it from the aircraft, upload it to DropBox, and provide a link to it here someone will take a look and can shed more light on what occurred. The instructions for retrieving the TXT file are at the link I provided, and the ones for accessing a DAT file are here.
