Focus issues when flying 3D mapping missions with GS pro
919 3 2017-12-9
Normko
I'm having issues with GS Pro and the focus on my images when flying a 3D mapping mission. I have an M200 with x4s camera.  I used the tap to focus but it does not relay any info if the focus was successful.  Also when I fly from bare ground to a forested area the focus is out and fuzzy in the treed area.  I'm not certain if there is a setting so that the camera can continually auto focus depending on the scene or do I have to continually tap the screen?  I'm not even sure if I'm doing it correctly.  I tried tapping and the first time a green box appreared in the screen, then the next time nothing and all other times after no green box.
2017-12-9
fans055ecaa4
Flight distance : 990256 ft
Poland
You can try getting a second remote to control just the camera
2017-12-14
ETA
Flight distance : 3032966 ft
I have been using maps made easy it has been working well with my 210
2017-12-14
Olivier Vietti-
Flight distance : 11618934 ft
Switzerland
The trigger button has two pressure positions, it is necessary to press lightly and hold and once the focus is done, press firmly
2017-12-14
