Dockater
Flight distance : 139649 ft
Flying from a moving vessel is not for a beginner, the only reliable way to finish a flight is by hand catching, you need one person to catch and one to fly and fly well. If the ship is stationary there is less of a problem. RTH is also a little complicated, I find the best is to set the action to HOVER at last known position, and you need to regularly update the “home-point” by resetting this to the controller. Note, setting the “home-point” to controller is not dynamic you must reset it often, so as not to leave it far behind you. Consider conducting your flight primarily ahead of the ship, in a quadrant of maybe 120 degrees, this makes it easier to return. When you are finished you will have to fly the entire maneuver to get a catch, this means adequate battery capacity must be available. The stell ship should not prove a problem to manual flying, I would not want to try a compass calibration on board though.
On that type of ship, on a canal or river estuary etc. there is not a lot of leeway for maneuver, even if the Captain wants to help!
