Gimbal not working properly. Gimbal status N/A
8208 19 2017-12-10
GreeZ
Hi there. I seem to have a problem with my gimbal on my P4. It wobbles about freely when I'm flying and refuses to work. On the aircraft status screen in the Go4 app it says my gimbal status is N/A. How can I fix this? I've tried factory reset using assistant 2.
Thank you in advance.
2017-12-10
fansa84fe8a4
Flight distance : 3 ft
Did you notice in the About if your Aircraft version was blank or not shown also?  Is this with an Apple device?
I'm having a lot of issues with GO 4.1.8 and Apple iOS 11.2 (iPad Air 2) with disconnects.  Starts out fine, but over time the C1 button to the gimbal fails (No up down.) and then various information begins to disappear in the About screen area as well as the EXP settings, Maximum Altitude and return to home altitude, etc.  If I unplug the USB cable and replug it, it all beings working again while in flight - for a while.  Dunno if it's GO 4.1.8 or 11.2, but 11.2 seems to have a lot of bad feedback for random crashes and more with 11.1 versions.
2017-12-10
DJI Diana
Flight distance : 2408 ft
Hi GreeZ, does the gimbal rotate when the drone is powering up? Can you control the gimbal tilt? When did this issue start? Did anything happen before, like hard landing or crash?
2017-12-11
GreeZ
DJI Diana Posted at 2017-12-11 02:01
This is only my first flight. The gimbal does rotate during power up. I cannot control tilt. Also I can't record video, I'm not sure if it's related or separate issue.
2017-12-11
DJI Diana
GreeZ Posted at 2017-12-11 02:14
Have you tried to press the record button on the RC to record video? Do you have video feed on the APP? Could you please provide a short video about this issue for better assistance?
2017-12-11
GreeZ
DJI Diana Posted at 2017-12-11 03:56
OK I will try to make a video. I haven't tried the record button on the RC. I will try.
2017-12-11
ALABAMA
Flight distance : 10442687 ft
Is it brand new?
2017-12-11
DJI Diana
GreeZ Posted at 2017-12-11 09:07
Okay, please keep us posted.
2017-12-11
GreeZ
DJI Diana Posted at 2017-12-11 20:21
2017-12-12
GreeZ
Yes, it flys perfectly but obviously I can't make any nice footage with it.
2017-12-12
ALABAMA
I would send it back.
2017-12-12
info-sp9
Flight distance : 220581 ft
Argentina
I have a similar problem that started when I updated firmware 2.00.0106 and I can not fix it in any way.
https://forum.dji.com/forum.php? ... D368%26typeid%3D368
2017-12-12
DJI Susan
GreeZ Posted at 2017-12-12 04:46
Here's a quick video I made to show the problem.
GreeZ, it looks like the hardware issue and we'd suggest to send it in  Please start a case from here and send it in at your earliest convenience: https://www.dji.com/support
2017-12-13
DJI Susan
info-sp9 Posted at 2017-12-12 05:23
https://forum.dji.com/forum.php?mod=viewthread&tid=123602&extra=page%3D1%26filter%3Dtypeid%26typeid%3D368%26typeid%3D368
Sir, I've replied you in your own post, please check and confirm, thanks!
2017-12-13
djiuser_7PurKLtMOGIp
Flight distance : 2654 ft
hello grez. did you resolve the problem with the gimbal? i have the same issue. my gimbal is moving but i dont have image.
2019-9-11
DJI Susan Posted at 2017-12-13 23:05
hello susan i have the same problem with my gimbal. what hatdware problem could it be. the core board or gimbal cables?
2019-9-11
DJI Susan
djiuser_7PurKLtMOGIp Posted at 9-11 15:15
This can be confirmed after damage assessment, sorry about that. You may start a case and send it in for diagnosis here: https://www.dji.com/support thanks!
2019-9-12
djiuser_bdNjriX1CXDN
India
Hi my phantom 4 gimbal is showing N/A there is no gimbal celebration while staring the drone but I can record video and take photos apart from that there is no movement in the gimbal I have replaced flex cable 2 time's still not working  please help me out
2020-3-31
djiuser_SVkhuXM50p8F
Brazil
djiuser_bdNjriX1CXDN Posted at 3-31 12:29
I'm just problem too in my Mavic 2.
Anything solution?
2020-4-17
MagoSaGazzu
Flight distance : 37802 ft
djiuser_SVkhuXM50p8F Posted at 2020-4-17 10:08
Anything solution?
Same problem with my mavic 2 zoom, gimbal n / a no move but I have video and zoom
2021-5-26
