fansa84fe8a4
The Apple Store has the GO 3 app. It's identified for the Phantom 3 if you read the info.
As to Androids, neither of mine (Samsungs) connect 'reliably' (Sometimes they will, but often they don't.) and why I went to Apple which worked well for several months. Sadly, now the Apple iPads I have are having issues and it seems to revolve around the USB connection to the RC. Actually, that issue seems to also be a reason the Samsungs fail to connect as well. Could be the RC wants to act as a charger and not as a data line, but no way to stop that. The Apples will disconnect in time while flying and I suspect it might be iOS 11.2 causing the issues.
I dunno. Seems it works or it doesn't. Good luck!
