wireless image transmission skips frames
1702 25 2017-12-10
fans2b56e667
Flight distance : 606152 ft
Chile
Any idea why it looks like this? the transmission is not fluid (but then on the computer it looks perfect), I tried with another control and nothing, with iPad and iPhone but it's still the same ... it's as if the Shutter was at 15 or less ... but it's in 1/160 ... I deactivated Video Cache, I tested the signals automatic and custom in all the bands and nothing ... the decoding hardware activated and deactivated, updated drone, camera, control and batteries did not work either... it is possible that a bad cable connection is causing it? appears at times "STRONG WIRELESS INTERFERENCE" I would appreciate your help. Check the Video with my ph4 and my inspire 1 pro using the same cable, iPad, in the same place::
2017-12-10
Hello, Sir, thanks for the feedback, just to verify, did you try other place like outside? Will the image transmission have the same problem?
Besides, what channel did you select? Auto or Manual?
2017-12-11
fans2b56e667
Chile
DJI Mindy Posted at 2017-12-11 03:47
yes, outside have the same problem, and I try in Manual all the channels and Auto, but nothing...
2017-12-11
Donnie *
Flight distance : 3636782 ft
fans2b56e667 Posted at 2017-12-11 05:17
You need a better Go app device that can handle the frame rate on the New Inspires.  Try to get and Apple I pad Pro or something with a super fast processor an A9 or A10 on the apples are the best .
I use and I pad pro and have no issues ,  read my tips as well but Image is almost always the fault of the Go app dfdevice.
donnie
*** I do NOT work for apple !!
Video Transmission issues with X3 or X5 ? Try These Suggestions !
2017-12-11
fans2b56e667
Chile
Donnie * Posted at 2017-12-11 05:44
I tried with iPhone 6, iPhone 5s, iPad Air, and nothing bro.... X5 camera..
2017-12-11
Mark Guille
Flight distance : 2031818 ft
Jersey
He does you know.
2017-12-11
Donnie *
LOL, you are funny one Mark , you need to keep it on the down low , Your check will be arriving soon .
SHHHH
donnie
2017-12-12
LIVNXXL
Flight distance : 1806125 ft
Jamaica
would I be correct in saying it is the GOAPP but not the GO4 that is the problem?
2017-12-12
LIVNXXL
Jamaica
fans2b56e667 Posted at 2017-12-11 07:08
All the devices you tried it on are the older processors. Donnie is saying you need the A9 or A10
2017-12-12
Donnie *
LIVNXXL Posted at 2017-12-12 09:03
Either one will work  I personally have an I pad Pro ( standard size )  ( with GPS and Cell, do not need to get the cell activated ) with the A9 processor  and it works perfect.
Also I want to give you my tips page with other ideas as well.  95% of the time a broken image is the fault of the go app device , and almost a certainty if using a older go app device .
I have seen. this many many times
good luck
2017-12-13
fans2b56e667
Chile
Donnie * Posted at 2017-12-13 05:33
Thanks bro...
2017-12-14
Hi Sir, sorry for the late response, if the problem persists after trying a mobile device with fast processor, please send in the drone for diagnosis, it could be the issue of Air End inside the aircraft.
We apologize for the inconvenience caused.
2017-12-15
mixchief
Flight distance : 182057 ft
My iPad Air 2 works perfectly however iPhone 6 is aughful, can't use it at all, flickers, black screen green screen scan, the works. I hate to think of the expense but I might have to go to either a new phone or replace the iPad with a CS or Epson BT300 glasses since there seems to be a hack to load Litchi on them
2017-12-16
Mark Guille
Jersey
mixchief Posted at 2017-12-16 22:45
Have you tried the BT300? I like the idea but don't want to fork out that sort of money if they're not up to the task.
Mark G.
2017-12-17
mixchief
Mark Guille Posted at 2017-12-17 02:02
Mark G.
I feel the same way Mark, concept is great, but I fdo wonder if it'll get confusing to the brain if not the eye. Haven't tried, did attempt the DJI goggles but wouldn't stay on my head, it was so bad I refused to liftoff with them on, going to try fatsharks for grins and giggles ig I can get some used real cheap.
2017-12-20
Mark Guille
Jersey
mixchief Posted at 2017-12-20 09:13
I like the idea of being able to see the AC at the same time as the live feed but just not sure how good the view would be on a bright day. Like you say, great concept.
Mark G.
2017-12-20
Dalib29
Flight distance : 598724 ft
U.S. Virgin Islands
good day everyone-
first post..
i fly my i1, p3 pro, i2 with the Fat Shark dominator V3 and ipad mini4, it is enjoyable. its very good on sunny days. the dji goggles seem too "clunky" for my taste. i have read the BT300 works wells with these AC and i am thinking about getting a pair. i also like the concept of viewing the AC along with the live feed at the same time.
Dion A
2017-12-21
fansb8e7e5a8
Flight distance : 22451 ft
Mindy , i noticed your help or suggestions re wireless interference issue, my issue the same, even changed I Pads. But you brought up. Auto or manual on channels. I did check one of the times on manual and it showed all channels poor with one. Channel 20 good. But still getting warning.  Thx Greg
2018-1-6
castormalin
Flight distance : 638911 ft
Hi guys,
I have the same problem, but with a Crystalsky. With my Iphone 7+, the Inspire is working fine.
If you have time, can you look here and exchange some ideas ?
https://forum.dji.com/forum.php? ... 27902&fromuid=55491
I'd like to downgrade the Inspire 1 pro for a test, to V1.08.
Is it possible ?
2018-1-6
DTK
Flight distance : 1943159 ft
What is your present FW version? No going back if you are on v1. 11. That was in the release note when you did your upgrade.
2018-1-6
castormalin
I am on V1.11...
Question : why it is possible to downgrade the RC to 1.6 thru the appli, but not the AC  ???
Since the RC at 1.6 is not able to connect to the AC at 1.11 (I tried)
It's stupid
2018-1-6
fansb8e7e5a8 Posted at 2018-1-6 09:38
Greg, may I know the model of your drone? Does the error occur in every place? Have you tried to to reinstall the DJI Go APP?
2018-1-9
Gregs77
DJI Mindy Posted at 2018-1-9 04:21
Mindy, sorry on the delay, had my father in hospital.Good news , interference problem gone, but had minor crash and gimbal locked up. So waiting tillDji opens tomorrow to swap out another one. To answer your question i have the mavic platinum pro. one thing i did do was shut off my wifi calling under setting when i fly now.
2018-1-29
Gregs77 Posted at 2018-1-29 00:40
Gregs, sorry to know your father was in hospital, hope everything goes well.
Please send in the drone at your earliest convenience and the repair team will take care of it for you, please keep me updated if you need any assistance.
2018-1-29
Gregs77
DJI Mindy Posted at 2018-1-29 01:07
yes thank you dad is alot better, and im just waiting for tomorrow am to call service.  thx again  Greg
2018-1-29
Gregs77 Posted at 2018-1-29 01:22
No problem, please post the case number here if you need any further assistance. We are always here to help.
2018-2-3
