fans61699a75
Flight distance : 24897940 ft
DJI Thor Posted at 2017-12-11 22:48
Hi there, if it is flashing fast, it is RC signal lost, first, considering a previous post that you mentioned about the RC and drone firmware, you might need to check if there is a need to update the RC's firmware, or you can provide me with a screenshot of the firmware info and I will help to check, here's the route: power on the drone, RC, app and enter device---upper right icon---general----about.
If it is not, since you had mentioned in another that it flashes 3 times once, it means the drone vibrates too much, did you fly the drone in a place with a strong wind, or is there any damage on the props, or is there any abnormal behavior on the motors or the arms? Try to calibrate the IMU and check again. Thank you.
https://www.youtube.com/watch?v= ... sG0MvxD4Dm-tX4cnvzX
Hello thor,
all to recent fw updated // no warning messages what so ever. yesterday the wind was fairly strong / flew within sight / open snowy field at approximatie 20-25 meters height
today same occurrence 3 fast flashing lights briefly ,but went quick into green again.
but I found another thread https://forum.dji.com/thread-109932-1-1.html in which you gave following answer ]"Yeah, it is confirmed by our engineers that triple yellow LEDs appear when high-frequency vibration was detected by aircraft IMU. Please fly with smooth control. Thanks for bringing us
the attention "
further information during flight: there was no strange behaviour of the drone, normal control/no lost / and
I could continue flight. can you please advise if engineers are still working on this issue?
I just one to know if i just can continue flying or is it a serious problem? |
