Summit Link Mount for 10 Inch IPAD - HELP
2444 30 2015-4-15
allbritt
I just received the UCTOPFPV Sunhood for the phantom 2 ( 10 or 7 inch )    X000NY4XDT.    I am trying to hook it up to my phantom 2 (V3) remote control.  The diagram shows I need to hook the mounting clamp to the angled bracket that comes with the phantom transmitter.   My angled bracket has a clamp on it for the iphone or galaxy similar to a oversized clothes pin.  ( see attached photo )
How do I get this thing to mount??
2015-4-15
Gerry1124
Take out the screw from the phone holder ball mount clamp apart and use it to mount to the bottom ring of the new clamp.
2015-4-15
allbritt
OK.  Thanks.  That works!
2015-4-15
Gerry1124
Take the ball mount clamp off the phone holder from the red circle and attach the 2 parts to where the green circle is and screw back together.
2015-4-15
i_anderson
You're not going to use the big clothes pin!
Take the nut off the back of the big piece. Put that "ball mount" over the ball, slide up the nut that's already there, and screw onto the big piece.... Note that it'll be "backwards" - You're looking down at it, so "righty-tighty, lefty_loosey" does not apply..... ;)
The mount is sprung loaded - Pull top & Bottom, slip 'er in, and let go. Done.
Adjust for a comfortable balance - I haven't got mine with me now, but IIRC, I turned it "upside down" - It puts the pad over the left stick, but it's cool, and the balance is better, at least for me.
Then tighten everything down - You don't want it going droopy in flight! ;)
Cheers,
Ian
2015-4-15
i_anderson
Gerry1124 Posted at 2015-4-16 07:34
Take out the screw from the phone holder ball mount clamp apart and use it to mount to the bottom ri ...
You are, of course correct! It was that part that allowed me two options for location IIRC?
2015-4-15
Gerry1124
I have 2 of the same clamp.
2015-4-15
Gerry1124
i_anderson@iclo Posted at 2015-4-16 07:46
I have a 10 inch tablet and the center mount didn't give me any clearance from the tx.  I epoxied the part to the back of the clamp because the tablet set so high, it wanted to bend the plastic out from the bottom if it leaned over backward.  I was afraid it might break.
2015-4-15
i_anderson
Gerry1124 Posted at 2015-4-16 07:52
I have a 10 inch tablet and the center mount didn't give me any clearance from the tx.  I epoxied  ...
Gotcha.
Two is good!......
I'd post a pic of mine if I had it with me.
2015-4-15
jtrjr
Flight distance : 4341 ft
Here's how I did mine. Easily change to any tablet or phone. Homemade but works great!
Jerry
2015-4-15
jtrjr
I can't figure out this picture stuff for the life of me! Arrrghhhh!
2015-4-15
Gerry1124
jtrjr@yahoo.com Posted at 2015-4-16 08:21
Use the bottom square and click on the paperclip.  Add photo and some writing in the square.
2015-4-15
jtrjr
test, test, test
2015-4-15
Gerry1124
Click on the paperclip and select your picture.  You will see it listed right above the post reply button
2015-4-15
jtrjr
It doesn't work that way for me.
2015-4-15
Gerry1124
jtrjr@yahoo.com Posted at 2015-4-16 08:43
That rots
2015-4-15
jtrjr
Maybe I'm not allowed. I tried the paperclip, the picture box, multiple times. Tried just copying to the clipboard and pasting, nothing...
2015-4-15
Raybro
Flight distance : 11099 ft
Ruh Roh....
Did you try copy this: C:\Temp\iPad Mount\IMG_5161.JPG    Open the little picture box.
Then paste it into the address box?
2015-4-15
jtrjr
Raybro Posted at 2015-4-16 08:53
Ruh Roh....
T ...
That's what I did Ray. Bro, we've been spouting about using computers with wordstar and floppies. I'm not a total dunce when it comes to computers. It just plain doesn't work. At least not on this computer. I'll try the other one next time.:@
Jerry
2015-4-15
jtrjr
2015-4-15
jtrjr
Forget it, no pictures from me!
2015-4-15
Raybro
Just checking.......we're good? Probably your browser....cookies...cache
2015-4-15
Gerry1124
pic 1  click on paperclip, you will see pic 2
double click pic and you will see pic 3 with the pic listed
add text here and post reply
2015-4-15
jtrjr
I just don't get it. Should be so simple. All's good, just no pics.
At least I still get to do the little dumb faces!
Jerry
2015-4-15
Gerry1124
jtrjr@yahoo.com Posted at 2015-4-16 08:45
Maybe I'm not allowed. I tried the paperclip, the picture box, multiple times. Tried just copying to ...
Here's 3 pics to help
2015-4-15
jtrjr
Okay, one more time...Click paperclip...select file from drive...file in box...select open button...nothing...I don't get screen #3. I don't get the item that you have circled in screen #3, it just kicks me back to this box in the thread. No worry, I don't want to waste anymore of everyone's time with this. Thanks Gerry, at least I know that yours looks different. Obviously, mine isn't picking up the file.
Jerry
2015-4-15
Gerry1124
jtrjr@yahoo.com Posted at 2015-4-16 09:26
Okay, one more time...Click paperclip...select file from drive...file in box...select open button... ...
That's sad
2015-4-15
allbritt
Thanks to all for the help.  I got it installed and can't wait to try it out.  I will be nice being able to see.  The iphone screen is so small.
2015-4-15
bahamasboy
Flight distance : 13845 ft
Jerry... the problem is not what your doing!!!  The problem is that the picture is too large.   What program do you use to view your pictures on your computer??  I may be able to walk you thru it IF that program has an option to reduce the file size.
2015-4-15
jtrjr
bahamasboy@aol. Posted at 2015-4-16 11:15
Jerry... the problem is not what your doing!!!  The problem is that the picture is too large.   What ...
Bahama,
I can reduce the picture sizes. Do you know what the limits are? What works well? You may be right, it slipped my mind and I didn't even think about it until I read your post. I'm going to try it right now. You got it, Brother! Reduced it and it went right in! I always put my cameras on the highest setting, you can always reduce but you can't expand. Damn, I can't believe I missed that!
Thanks for the help,
Jerry
2015-4-15
bahamasboy
GLAD you got it!  I don't know the limits but from what I've uploaded, I think they need to be under 1 MB.
TEAMWORK!!!!!
2015-4-16
