Mark The Droner
Flight distance : 2917 ft
Remember your drone was first released in the spring of 2014 which is a long time ago in the tech world. The first problem sounds like you have the "black screen." To fix it, you need to flash the NAND which is on a board inside the wifi module. There is a youtube vid showing you how to do it and what tools you'll need but I think it requires a windows desktop. You can also send the wifi module to a guy on eBay who will flash it for you for $80. I recommend OKSTUV for the job. Re the second problem, green and 3 reds would mean you are in NAZA mode and it's telling you that you have four satellites or less - ie you're in ATTI mode. Green yellow 3 reds I'm not sure of. Re the third problem, I know there is an issue with the more modern windows systems in that you must disable the Driver Signature Enforcement of your win os for the Phantom 2 Vision+ Assistant software to work. It will reset itself automatically on your next desktop reboot. How that applies to a MAC I have no idea. Good luck. |
