HOW TO UPDATE FIRMWARE ON MULTIPLE BATTERIES
2332 13 2015-4-15
GENETTICO
As I did it, but not the only way... (Assuming you already did first battery along with bird and remote controller)
http://youtu.be/zZH07LEHpPg
1. Download firmware and extract files.
2. Erase all data on a micro SD by formatting or deleting all data (quick format ok) and add just the firmware by itself (see video). (After first update just delete everything and leave the firmware software by itself and continue on to next battery. I even deleted the camera folders created... It will create them if they are not there everytime... See video.
3. Insert SD card on I1.
4. Turn RC on. Wait for it to initialize.
5. Turn APP on. wait for it to initialize. Accept and the "trust" warning.
6. Turn bird on. See video.
7. Wait and let it initialize. If it needs to update firmware on battery it will tell you on app and start updating at the same time (see video). 4 shorts beeps followed by silence and repeats means it is updating... Long beep followed by two short beeps means it is complete... (See video) use the beeps and not visual on app. See vid.
8. Turn Bird Off.
9. Turn app off.
10.Turn RC off.
11.Remove SD card from bird. See video.
12.Insert SD in computer and browse to it.
13.Verify .txt file. See video if "abort" message comes up the battery already has latest firmware, if it updated firmware it will hopefully say "success", if "failed" message go back to 2 and repeat steps. If success or abort go to step 2 and repeat process for next battery.
I know you can also update batteries without remote and app being turned on, but I like to be able to see confirmation on app..
Hope this helps...
2015-4-15
Wolfman
Flight distance : 405659 ft
Video is private mate
2015-4-15
GENETTICO
Wolfman Posted at 2015-4-16 09:58
Sorry about that! It is public now!
2015-4-15
dbeck
I thought the instructions specially said DO NOT TURN THE RC on!!!
2015-4-15
GENETTICO
dbeck@promobox. Posted at 2015-4-16 10:47
I READ the instructions a few times before updating and before making video and this thread and actually does not specify either way!
2015-4-15
dbeck
Step 3...#1..says..."ensure the RC in turned OFF..."
2015-4-15
GENETTICO
dbeck@promobox. Posted at 2015-4-16 11:08
Yes... But that is for the bird not the batteries!
2015-4-15
dbeck
AH...well, I'm hesitaintg to do anyhting.  My bird is perfect...why update?  I'm a pussy...I admit it
2015-4-15
GENETTICO
dbeck@promobox. Posted at 2015-4-16 11:27
AH...well, I'm hesitaintg to do anyhting.  My bird is perfect...why update?  I'm a pussy...I admit i ...
Where I bought my bird (UAV Outlet -Florida) Chad told me that you only get three flights before the bird will no fly until you update to latest firmware... Do you know if this is the case?
2015-4-15
dbeck
I've had 10 flights...no issues..its says..."update required..."  I disregard...I'm of the old..."if it aint broke..etc.,"  I'll wait, I'm sure another update is coming
2015-4-15
GENETTICO
2015-4-15
GENETTICO
This is the section for aircraft scroll down for battery
2015-4-15
bornish
Flight distance : 91447 ft
United Arab Emirates
dbeck@promobox. Posted at 2015-4-16 11:31
I've had 10 flights...no issues..its says..."update required..."  I disregard...I'm of the old..."if ...
Are you sure it ain't broken? According to many reports in here, the firmware was responsible for quite a few mishaps. According to some beta testers, this update is supposed to fix them.
Good luck though...
2015-4-15
dbeck
No problem at all thus far. I aint updating yet.
2015-4-16
