joenaylor
Flight distance : 81752 ft
Dji Susan you saved the day. After trying just about everything else your suggestion about the Image Transmission Code Rate worked.
However, there is a twist.
The Transmission Code Rate is not available in the HD menu until the channel mode is changed from Auto to Custom, and the Custom menu is normally not available on my Ipad 3 mini. However, after a long time of searching posts I found someone mentioned that the Custom menu is not available when DJI Go thinks the drone is not in the USA. It evidently does this by checking the IPAD language setting. I found that by changing the Ipad language to English (U.S.) in the Ipad Settings menu (even if it already says English U.S. just change it anyhow) then opening the DJI go app, I can set the Channel Mode to Custom and then the Transmission Quality setting is available. By moving the slider to 6Mbps the problem is solved. For some strange reason the Transmission Quality will not go any lower than 6, but 6 seems to do the trick.
