Video Trans. ok, but the pitch motor gets stuck at certain angles.
1026 4 2017-12-11
User11432
Hello,
I am having problems with the up and down motor on my p3 standard gimbal. I power up the drone and it all spins around fine, I go to move the camera up and down but it moves a little and gets stuck. I bought the drone new from eBay less than 3 months ago and it worked fine until now. I have not crashed it, I cannot think of anything that would have caused this. If anyone has any insight at all into this matter, anything is appreciated. Thanks !
2017-12-11
DJI Diana
Flight distance : 2408 ft
Hey, have you got any error message in the APP? Please do a gimbal calibration, see if it can be finished successfully. Besides, please try to reset the gimbal settings (Gimbal Settings--Advanced Settings--Reset Settings). If it persists, please post a video about this issue for better assistance.
2017-12-11
fans28f73dcb
Flight distance : 141191 ft
Check for ribbon interferance. Mine came unglued and gets in the way when moving lens up and down
2018-7-1
Peterx
Flight distance : 1499708 ft
Were you take off and land your P3S on dusty or sand ground. May be you get a little bit sand core in to the pitch motor of the gimbal.
If it ´s so then take a blower and blow that out of the motor.
2018-10-18
fans28f73dcb
I'm with fans check ribbon cable for interference.
2018-11-3
