theglovebox
LouisP Posted at 2017-12-14 15:28
Yes that is the way it works, unfortunately. The way it SHOULD work is that if you are not recording video when you start a quick shot,it should do as it does and stop at the end of the maneuver. But, if you are in record at the start of a quick shot, it should continue recording. Maybe somebody at DJI will see this and fix it in future software.
I may have come to this thread a bit late. I am new to the Spark. I am encountering a similar issue. With the Rocket mode, it only records 10 seconds of flight, a couple of which are as it manoeuvres closer and then goes up. It says somewhere it will only climb at 2m/S, meaning the max height that will get recorded is 20m - why then can you set it to 40m. Am I missing something?? |
