Using new 8331 propellers on Mavic Pro hitting the body
3681 26 2017-12-12
vincent_222
Recently purchased the new blades and love the new look and certain noise reduction however they seem to be hitting the front left of the body and the top of the arm. I can hear it contacting the quad (when in ear shot) but only when decending at full throttle while flying forward. I use the Mavic Pro a lot and have had no issues with the original propellers and so have gone back to them in the mean time. I was really wondering if anyone else has this issue and/or has found a way to stop it damaging the body? edit - the drone has never been crashed or damaged in anyway
Marks on the front of the body and on the arm
Scuff on the bottom and tip of the 8331 propellers
2017-12-12
WolfgangStiller
Flight distance : 599416 ft
Wow--first report I have heard of this--thanks for the heads up.
2017-12-12
PHL
Flight distance : 1044062 ft
Has anyone else noticed this? I'm surprised it can happen, as I'd have though the props were not that much different in length compared to the original. I am looking at getting a set for travel, so as to be more discrete when using the Mavic, but hitting the body isn't a great thing.
BTW, the prop isn't bent, is it?
2017-12-12
A CW
Flight distance : 13877205 ft
No problems using the 8331’s on my Platinum but the clearance is MM’s from the main hull of the Mavic. First I’ve seen this. Did you buy the props from DJI or a third party via Amazon/EBay?
2017-12-12
jcgoobee
Flight distance : 476119 ft
Odd. I've been flying with my 8331 for close to 3 weeks now and don't a single scratch on the body. Did you purchase the props from a reputable reseller?
2017-12-12
STRIDE8
Flight distance : 1382431 ft
Do the yellow tips angle up? if so how did the top of the prop get scratched up like that?
2017-12-12
Thudd
Flight distance : 1624787 ft
Was a tree involved?
2017-12-12
Sim-Y
Flight distance : 75502 ft
STRIDE8 Posted at 2017-12-12 14:40
I was wondering that, it also looks like the trailing edge as well, very strange.
2017-12-12
bighi
Flight distance : 47455053 ft
Austria
While I didn't have that issue, I chose to stop using the 8331 propellers. While I liked the noise reduction, I chose to take a little more noise in order to have piece of mind. The 8331 propellers seemed way too flimsy for my tastes.
2017-12-12
Koia Koia
Flight distance : 772867 ft
I think in the photo the prop is off and upside down so your seeing the area on the bottom of the prop that is rubbing.
2017-12-12
$gambino$
Flight distance : 1563980 ft
I have vibration issues with the gimbal with mine. So I went back to stock..... Op are these dji brand or another brand?
2017-12-12
$gambino$
Koia you are right but I just think the prop is off the mavic pro not actually upside down
2017-12-12
Lucas775
Flight distance : 50642090 ft
Haven't seen this before.
2017-12-12
fans589cba4b
Flight distance : 12780633 ft
mine dont. are your arms loose maybe from a previous crash or hard landing?
2017-12-12
DJI Thor
Flight distance : 13602 ft
Hi Vincent, so according to your observation, it only happens when descending at full throttle while flying forward, it is normal with other controls, right? I will forward your case to our engineers to confirm, will get back to you once I hear from them, and thank you for bringing us the attention.
2017-12-12
Locoman
Flight distance : 748675 ft
Question, where did you get the props, are they DJI or second market. Where you flying in sport mode. one or both of those issues could cause this.
2017-12-13
vincent_222
Sorry my fault I should have said that was the underside of the propeller shown in the photo
2017-12-13
vincent_222
DJI Thor Posted at 2017-12-12 21:13
Yeah no problem in all other flying conditions that I can tell. Thanks
2017-12-13
vincent_222
Locoman Posted at 2017-12-13 03:47
I bought them from the DJI store so think they are OEM
2017-12-13
vincent_222
Should have mentioned that the picture with the propeller in has the propeller removed and is showing the underside chafing. And these propellers are from the DJI store. The propeller doesn't seem to be bent when comparing to the back right (same prop)
2017-12-13
DJI Thor
vincent_222 Posted at 2017-12-13 05:04
Thank you for your update. I had informed our engineers to check, haven't heard back, please kindly wait patiently.
2017-12-15
DJI Thor
vincent_222 Posted at 2017-12-13 05:09
Hi sir, an update here, may we know where do you fly the drone, the altitude of the environment as well as the temperature? The info is needed. Thank you so much.
2017-12-18
DJI Thor
Hi, Vincent, I got an update from our engineers: it seems the loose of the related part. Please check the arms and motors and the motors mounting plates and see if there is anything working loose.
Please send it back for an overall check, please fill in some info on our online repair link of our official web and then send it back. Here is the link: https://repair.dji.com/en/SelfRepair/Area
Or please avoid the way of flight which causes the issue. Thank you.
2017-12-22
alex_markov
Flight distance : 39244380 ft
Bulgaria
I had the same, BUT wit props both from Amazon - Definitely Fake - on a box, there was no DJI sign, but "for Mavic...". Put the second set of originals and have No problem!
https://forum.dji.com/thread-120972-1-1.html
2017-12-22
Range925
Flight distance : 11281079 ft
Are these actual props from the actual DJI store or DJI Authorized dealer? A lot of fake DJI props are being sold so be careful.
2017-12-23
CoreyB10
Flight distance : 1665023 ft
PHL Posted at 2017-12-12 13:57
Not noticed this before and I have had mine on my Mavic since purchase. very odd indeed.
2017-12-23
djiuser_VNW2TNbwCffh
I have the exact same problem, even on the left side just like you.
2021-10-11
