Drop of frames (lag) on CrystalSky
12
7658 49 2017-12-12
tiirikka
Flight distance : 149718 ft
Finland
Any help with Inspire 1 lag problems. I have same difficulties as first topics.. Nothing helps and firmwares has been updated. No focus peaking switched on. When I use ipad or iphone -> no problem. Only lag problems with inspire 1 and CS 5" and 7". Mavic pro -> no problem.
Lag issues are always, no matter if you fly in city or in forest..
There might be possible that lag issued came when last firmware was installed. Because some time a go there were no problems.. Any step by step help or do I just need send both CS to service?
2018-7-17
tiirikka
Finland
tiirikka Posted at 2018-7-17 03:17
2018-7-17
tiirikka
Finland
2018-7-17
tiirikka
Finland
Here are links to show how it is
And if I open some of settings in app, lag issue goes away...
2018-7-17
AnaMar
Estonia
How its work on PAL video mode? My Crystal Sky Ultra was dead yesterday (was sent to repair) . It s all started with delays, half squares, what i wrote in previous posts.
2018-7-17
tiirikka
Finland
AnaMar Posted at 2018-7-17 07:44
We use always PAL, because NTSC is not supported in Finland. I still tested both of them and no difference.
2018-7-18
PNad
I have the EXACT same problem with my M600. Choppy feed but when I open the settings menu its super smooth.
Turn off all the dji go GPS stuff that you can in the app setting, you lose some fonctionnality but at least the video feed is smooth.
2018-7-19
Ugashik Bob
Flight distance : 11150600 ft
After updating to levels shown in attachment and doing all the calibrations still saw video lag on first test flight recording at only 2.7k. Maps are still useless and  System Error/Beep message on Cendence is still there. Video lag goes away if I switch to ipad pro 10.5 at IOS 11,4,1/
2018-7-20
FlyGuy
Flight distance : 106483 ft
I've given up using Dji Go with Inspire 1 and CS. With the Inspire 2 it works fine. When flying the I1 I use the Litchi App in the CS. There's still some lag but way less then flying with DJI GO
2018-7-20
AnaMar
Estonia
How to put the old firmware and DJI GO 4. The newer the firmware goes, the worse the screen works.
2018-8-18
12
