Finding out why Spark crashed into the water flying under a bridge
1053 6 2017-12-12
djiuser_tGYKEfH
Flight distance : 80522 ft
I was tring to fly my spark under this small little bridge (see picture below). Was travelling really slowly in tripod mode. The Spark went into ATTI mode under the bridge, and after a while I lost connection with the Spark on my RC. Luckily I managed to retrieve the drone in the water, but i'm trying to figure out what exactly went wrong so I can prevent future occurences. Is it not recommended to fly under a bridge? Loss of GPS? Compass error due to metal structure?
Small bridge
Small bridge
Any advice here is appreciated. My flight log is here:
http://www.phantomhelp.com/LogViewer/2BL4Z4TQXNEUXUDHJJ28/
2017-12-12
S-e-ven
Flight distance : 5922034 ft
Thailand
' Is it not recommended to fly under a bridge? Loss of GPS? Compass error due to metal structure?'
Mostly all of the above.
I assume, in slow tripod mode, it lost GPS and had compass error, switched to atti and .....
2017-12-12
DJI Elektra
Hi, sir. I am sorry to hear that your drone dropped into the water. I would recommend you contact our support and start a case first: http://www.dji.com/support. Please forward the flight record to our support to find out the reason. I would recommend you upload the data to dropbox. Thanks for your support.
2017-12-12
hallmark007
Flight distance : 9827923 ft
You answered your own question, when you fly under something you lose connection with gps, also bridges are usually made from concrete rebar or metal structures so hence compass problem.
I hope you have Care refresh , but you just need to put this down to experience.
2017-12-13
A CW
Flight distance : 13838848 ft
Loss of connection in short - always maintain a clear line between the RC and AC - the bridge became an obstruction - signal lost, RTH activated and crashes into the bridge as it ascends.
2017-12-13
djiuser_tGYKEfH
Thanks, seems like we cannot be too ambitious with out flights! Thankfully I do have Care Refresh and the replacement is on the way back!
Do we often face compass error when flying near metal objects such as bridges?
2017-12-13
hallmark007
djiuser_tGYKEfH Posted at 2017-12-13 09:38
Metal is a serious problem with compass there is plenty in bridges also rebar concrete, keep clear.
Great you had dji Care this is exactly what it’s for hopefully you get replacement soon. Good luck.
2017-12-13
