Firmware ISSUES
1110 13 2017-12-13
fansb872acfc
Phantom 3 pro
Used last a year ago. I've been keeping the batteries charged month to month. Last use was with an iphone6+. Now using Samsung 8. Downloaded the pre 4 app. Also downloaded the bin file to sd card and had success updating the drone. Deleted text file from sd card and placed in the remote with no luck updating. I have tried this with 4 different ad cards. No luck.
Also when I connect everything and open the app, it only gives me the camera option on the inspire drone. When I put the phantom 3pro page up, it only offers the "how to connect" page.
What am I doin wrong ?
2 days trying and retrying
2017-12-13
Al S. Alice's H
Flight distance : 50259 ft
I had a similar experience.
Found out only 1 of the 5 USB cords would work. All made a battery charge connection, but not data.
Some were brand new!
2017-12-13
DJI Susan
Hey there, what's the current APP version? Could the drone be controlled by the controller? Does the issue remain if changed to another working cable or recommended mobile device?
2017-12-13
fansb872acfc
Hi. Thanks for the replies. I've tried every S8 cable I have to connect to the remote to look at the firmware version on the remote. It will not give the camera view option ! Only " How to connect" option.
Also the drone will not recognize the remote. And I have gone through the button sequence on the remote along with the reset button on the drone with no luck, all per DJI phone call.
2017-12-14
fansb872acfc
And I am using the pre 4 app offered on android.
2017-12-14
ALABAMA
Flight distance : 10442687 ft
Have you tried going back to the iPhone?
2017-12-14
Mark Guille
Flight distance : 2031818 ft
Jersey
The remote is now updated through the app, just make sure the AC is off when you update.
Mark G.
2017-12-14
fansb872acfc
I tried on a iPad air2 also. Still will not enable camera view on the app so that I can update the RC through the app.
2017-12-14
fansb872acfc
My problem. I have Phantom 3 Pro, not Inspire
2017-12-16
MattMan
Anybody fix this I'm having the same issue! Updated now I can't connect or get into the camera mode. Nothing works. Just before the update everything connected and all was working. I did get this error from the  AC update text
Packet: P3X_FW_V01.10.0090.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
tried 2 or 3 times always get the same error
any help would be appreciated
iPad mini 3
iOS 11.2.2
FW P3X_FW_V01.11.0020
2018-1-20
Aardvark
Flight distance : 384432 ft
MattMan Posted at 2018-1-20 16:35
Result: Corrupted.
When you download the file do you then 'extract' the file from the downloaded ZIP file before copying it onto the SD card ?
You could perhaps try reformatting the SD card, or try another card ?
2018-1-21
djiuser_gl6QNuvh5GV1
Flight distance : 18832 ft
My drone and remote same as above is there a fix or are we all stuck with dead drones
2018-2-9
Shredder
Flight distance : 10781 ft
Same thing here. It is reading the bin. I get  a  result message on the card that says  the rc  firmware is  newer than what I'm trying to install.
2018-2-11
Just to let others know
I found out my USB port on rc was broken got a rc off eBay go app works but still having trouble with no transmission signal
2018-2-18
