Hi, I want to switch 2.8Ghz and 5.2Ghz about Video transmission.
3396 14 2017-12-13
DarkGaia
South Korea
Hi there,
I'm newbie about Drone.
I have Galaxy 7 edge, Inspire 1. And I live in South Korea.
I figure out that Inspire 1 can use 2.8Ghz and 5.2Ghz.
So I wanna switch 2.8Ghz and 5.2Ghz about Video transmit.
But in android app, I couldn't find about that.
Question is how can I switch 2.8Ghz and 5.2Ghz??
Please Help me.
2017-12-13
Hi Gaia, the image transmission of Inspire 1 only works in 2.4Ghz frequency, sorry that the channel cannot be switched. Thanks for your understanding.
2017-12-14
DarkGaia
South Korea
DJI Mindy Posted at 2017-12-14 00:22
Hi Gaia, the image transmission of Inspire 1 only works in 2.4Ghz channel, sorry that the channel cannot be switched.
Thank You, So much!!
BTW, How about Inspire 2?
Can Inspire 2 switch 2.8Ghz and 5.2Ghz?
2017-12-14
DarkGaia Posted at 2017-12-14 00:42
Yes, Inspire 2 works in 2.4GHz and 5.8GHz frequency, you can switch them in APP settings.
Let me me know if you have further questions.
2017-12-14
DarkGaia
South Korea
DJI Mindy Posted at 2017-12-14 01:09
Oh, Thank U.
I have one more questions.
I heard that DJI Drones will be changed frequency by themselves.
If 2.4Ghz better than 5.8Ghz, they will change more better frequency automatically.
Is it right?
2017-12-14
DarkGaia
South Korea
DarkGaia Posted at 2017-12-14 15:52
Oh, Thank U.
So that I wanna add one more question, but I can't modify thread.
If I mount camera on Inspire, Can I turn off/on Camera for battery?
2017-12-14
Oh, Thank U.
Hi Sir, after powering on, the Inspire 2 will automatically choose a frequency band with less interference. Then the Inspire 2 will not switch to other frequency band.
Pilot can switch the frequency band in the DJI GO 4 app during flight, but the control signal and image transmission signal may be interrupted temporarily.
I'm a little confused about your second question, camera and gimbal cannot be used separately, they do not have their own battery or power. It's the same as Inspire 1.
Hope my answer will help you to get it clear.
2017-12-14
DarkGaia
South Korea
DJI Mindy Posted at 2017-12-14 23:19
I'm a little confused about your second question, camera and gimbal cannot be used separately, they do not have their own battery or power. It's the same as Inspire 1.Hope my answer will help you to get it clear.
I got a big one. Thank U so much.
I'm so sorry but I have more questions
Drone is So difficult to me
What is  coordinate system on Inspire 1?
WGS 84 or ETRS89 or Can I choose the one?
and another question is that how much gps error rate?
I want to make Large Map using Inspire 1. So I have to know that information.
Thank U so much Mindy.
2017-12-15
DarkGaia Posted at 2017-12-15 01:14
Hi there, we use WGS84 in Inspire 1 and the coordinate system cannot be selected by users.
The GPS accuracy is of the order of meters, but it can reach to more than ten meters or even worse if the GPS signal is not good.
2017-12-15
DarkGaia
South Korea
DJI Mindy Posted at 2017-12-15 03:40
Thank you so much!!
How about Inspire 2??
Is it Same??
2017-12-17
DarkGaia Posted at 2017-12-17 16:16
Thank you so much!!
Is it Same??
Hello Sir, right, Inspire 2 also adopts WGS84 coordinate system.
The hovering accuracy of Inspire 2 with GPS enabled:
Vertical: ±1.64 feet (0.5m) or ±0.33 feet (0.1m, with the Downward Vision System enabled)
Horizontal: ±4.92 feet (1.5m) or ±0.98 feet (0.3m, with the Downward Vision System enabled)
Thanks for your interest to Inspire 2.
2017-12-18
RichJ53
Flight distance : 1837356 ft
DJI Mindy Posted at 2017-12-18 21:08
HI Mindy
That's pretty amazing performance and I can confirm my Inspire 2 GPS works wonderfully.  When using the RC optional GPS module,  doesn't that give you better accuracy?
Merry Christmas
Rich
2017-12-18
fansb93fb02a
Flight distance : 70925 ft
RichJ53 Posted at 2017-12-18 21:20
HI Mindy
Hi I can only use channel 5.2 on inspire 2 . . . Is this good or bad
2019-6-21
fansb93fb02a
fansb93fb02a Posted at 6-21 09:44
Hi I can only use channel 5.2 on inspire 2 . . . Is this good or bad [view_image][view_image]
Why won’t it let me use 5.2 . But can on my mavic 2 ?
2019-6-21
RichJ53
Hi
I am not following your question? Sorry I just noticed your screen shots and 5.2 Ghz question.  So it seems this post was a couple of years ago. Could you please explain your setup and hardware being used? What are you asking, radio switching between 2.4 / 5.8 G? not sure where the GPS fits into this
I have not been flying much this past 6 months or with the GPS.
Rich
2019-6-27
