DJI Grace
Flight distance : 405039 ft
DJI BATTERY STATION
To ensure professional film crews with efficiency for every shooting task, DJI introduces a new battery station built specifically for the Intelligent Battery TB501. The DJI Battery Station is the all-in-one solution for battery charging, storage, and transportation, helping you to efficiently manage batteries for any film set.
Comprehensive Charging
With efficient, intelligent management, the DJI Battery Station ensures that shooting equipment is always ready to use. The Battery Station can charge up to eight TB50 batteries simultaneously. In addition, it can charge other devices including the Inspire 2 remote controller and WB37 Intelligent Battery2 via multiple charging ports, and even mobile devices via USB ports. Simply put, the DJI Battery Station is equipped to meet the needs of all your energy-dependent devices.
In addition to power, the DJI Battery Station provides vital information about your batteries to ensure proper management. When a TB50 Intelligent Battery is attached, its current firmware version will display on the station's LCD screen. When connected to a computer via USB cable, the Battery Station can update up to eight batteries to their latest firmware version through DJI Assistant 2 on the computer3.
The DJI Battery Station is built within a case that offers maximum storage. It can store up to 12 TB50 Intelligent Batteries, two WB37 Intelligent Batteries, and one WCH2 Charging Hub4. Outfitted with wheels for traveling, the Battery Station supports all-day shoots.
Multiple Charging Modes
On a film set, every second counts. To accommodate every critical need, the DJI Battery Station uses three charging modes - Normal, Quick, and Silent - to provide the best power management for every scenario.
In Normal mode, eight connected TB50 Intelligent Batteries can be charged simultaneously, until all batteries are fully charged.
In Quick mode, the four TB50 Intelligent Batteries with the highest battery level in the same group will be charged to 90% in just 35 minutes, making it a useful option for urgent use.
In Silent mode, charging speed is lowered to provide a quieter process for evening charges or when limited noise is permitted on set.
Sophisticated Design for Safety and Reliability
We understand that safety is a top priority when handling batteries, which is why the DJI Battery Station is designed with robust measures to ensure reliable charging and storing of all your batteries.
A built-in cooling fan dissipates heat during charging. Overheating Detection monitors battery temperature in real time to make sure that every battery stays within a safe range. If overheating is detected, the Battery Station will automatically cancel charging and discharging to avoid any safety hazards.
The DJI Battery Station is constructed of a plastic that meets USA UL94 V-0 flammability standards, reducing the risks that may arise in extreme environments. From design to materials, every aspect is secured and reliable.
1Applies to the Inspire 2, Ronin 2, and M200 series products
2 Applies to the CrystalSky monitor and Cendence remote controller.
3 Applies to the WB37 Intelligent Battery.
4 Compatibility available soon. A software upgrade will be required.
