Punchbuggy
Flight distance : 483166 ft
Well, it's a new twist to hear that the RC shows the link light as connected when the craft is powered off. So you're saying that the LED is green (linked), not red (not linked)?
I'd be thinking hardware fault, but I suggest you try to re-install the controller firmware (craft powered off, controller on, start app, press the three lines at top right of the Device screen for ~5 secs, select firmware level, let it update). Then do a reset and re-link as per the following.
Reset the RC:
* Turn on the controller, the aircraft should be off.
* Press C1, C2, and shutter (top right button nearest antenna) on the controller and hold for about 2 seconds or so until it beeps (D-DDD), then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
Re-link the RC:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep like D-DD.
* Let go all fingers, press the wheel on the right side of the controller, and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen or toothpick to click the linking button on the aircraft and hold for 3-5 seconds, and then remove and wait for craft to link. |
