hallmark007
Flight distance : 9812789 ft
Hi welcome to the beginning.
If you’ve got to problem 3 then 1&2 must be sorted.i have never used PC to download firmware on any of my drones it works just fine on using the app.
Gesture control can be tricky at first, but persevere, you need good light preferably wear bright clothes it’s something akin to a knack getting started and when you find the best way that works for you you will be up and running.
Updating firmware on batteries, you just need to start up Aircraft go into app it will prompt you it needs firmware so follow prompt app is all that’s needed, when finished repeat for all other batteries..
Just looking at you questions again you seem to have most solved.
One thing is you said you calibrated compass an IMU, why? It clearly tells you in your manual NOT to calibrate , most crashes here start with the opening line, I just calibrated my compass etc etc.
I wish you luck with your new craft and if you need help there are plenty of guys/gals around here who will help you.
