m.delfeld
Belgium
Hello to you all,
I have a problem with a micro SD card. The original one does not have this problem.
So I use a micro SD card 32 Gb Samsung EVO
On the app, the main screen at the top right, I get a message "Initialization of SD card in progress"
The same message appears in red in the General Setup screen.
I used this card this morning to update the driver. Everything is well spent. The drone flies, the two transmitters operate and respond correctly and flies drone without worry.
So everything is perfect except this "damned" SD card (the other does not display that message! It gives it's capacity in the General Setup screen.
The Samsung card is readable on my Mac. On the MAc, I've tried everything, delete all files, copy the directories good card to Samsung, reformat the card, etc ....
The message is still there! but the most strange is that despite what message the video recording functions and files are recoverable on the Mac!
Do you have an idea or suggestion?
Thank you in advance
