Ronin Noise Problem
1547 4 2015-4-16
info
I've tried all the possibility out here.
I have tried to balance perfectly the ronin,
i've tried lowering the stiffness
i have the lens support installed
i've tried both 2.1 and 2.3 firmawere.
Ronin is still noisy. With all the precautions the noise is reduced, but it is still clearly recorded by a middle to high-level microphone, making the Ronin useless in a cinematic enviroment.
Is incredible that having spent more than 2k $ I cannot solve this kind of problem, while chinese gimbal are sometime even quieter.
I've heard other people having my same issue.
I've herd about a "Silent Mode" in Ronin M. Will be also added to the Ronin?
2015-4-16
dmelhorn
Mine had the horrible vibration and noise when the Ronin was "properly balanced" and set-up.  Ironically, it went away when "improperly balanced" by dropping the camera to its lowest point on the vertical axis.
I cured my problem by dialing the "stiffness" back down to the 5-10 range.  Since then its worked fine in minimal testing with both a Canon C300 and Canon 5D.  It was amazing the difference that adjustment made.
With that said, I have not put it through a rigorous test run.  That is on schedule for tomorrow and furthermore next week.  She is not ready for a paying job, but I will keep you posted.
2015-4-16
info
Just let me know ho It works
2015-4-17
DJI-Cathy
Could you please show me a video?
2015-4-21
info
Copy the code
the buzzing noise you can hear during the whole video is made by the ronin.
https://www.facebook.com/Deadpix ... ?type=2&theater
2015-4-28
