losing the bind signal on the thumb controller (and the remote)
1143 1 2017-12-15
djiuser_s8CQ9go
Hi everyone
I'm at a bit of loss so am putting this out to the community brain.
I have a fairly new Ronin M and up until a few days ago everything was working fine, however today I have turned everythign on and I am having trouble with the thumb controller and the remote control.
on powering up the ronin the light on the ronin is constant but it looks like it's green and red at the same time (?) and when i first turn it on the light on the thumb controller stays green for about 10 seconds and then the signal display turns to an X and the light goes to red and blinking. When the thumb controller loses the signal the light on the ronin doesn't change. As an extra confusion the remote controllers ilght is a constant green when it's on but there is no response from the ronin when you move any of the controls.
When I try and press the bind button the ronin doesn't do anything unless I press and hold for a while when the light flashes red for a couple of seconds and then returns to where it was.
I have upgrade all the firmware on all three bits of kit and there is no change.
Any ideas?
Thanks in advance
2017-12-15
jakub_sipos
Slovakia
Hi, i have same problem. Di you fix it? Thanks
2018-2-9
