Texas-Mark
Flight distance : 23002 ft
WD9EON Posted at 2017-12-15 18:40
Why would you post in the P3standard forum? Not trying to be a jerk, but you may find it to your advantage to post in the correct forum. Good luck
When posting a new thread, unless you remember to use the drop-down to select the forum section you want, it will just put it in some random place even if you started out in the correct section. This forum is not always very intuitive (as compared to most of the others I belong to).
As for the OP'er, it is not much help now, but I have gotten into the habbit of using an apk extactor on apps before I update them, so I alway have a copy of the previous version in case something breaks.
