Bluetooth audio and Osmo mobile
3006 7 2017-12-16
Rmh1120
Hey all, I am running the osmo mobile with an iPhone SE. I would like to set it up with a Bluetooth clip on mic so I can take videos from farther away.
The mic I was looking at is Hey Mic, but there are other similar options. They all seem to require their own app and do not work with DJI.
What’s the best way to manage this? Using wondershare filmora for editing.
2017-12-16
Montfrooij
Flight distance : 2560453 ft
Why don't you attach a regular mic to the Osmo Mobile?
It will fit the SE with the minijack port still present.
2017-12-16
PHL
Flight distance : 1044062 ft
I can sympathise with where Rmh is coming from, as that’s what I’’d also like to do. The whole idea of the Osmo mobile is movement, but a tethered mic will run the risk,of entanglement, so this is also something I’m looking for. I’d rather not have to sync audio and video post-production.
2017-12-16
PHL
Actually found a good solution, but you can’t use DJI Go.
Currently tested on MoviePro, and set it up to use BT mic. I tested it using my AirPods as I have that on hand, and it works really well, no loss of sync. You do lose the zoom feature of the Osmo handle controls, but Record, pan and tilt all still works.
2017-12-16
Rmh1120
PHL Posted at 2017-12-16 17:18
Does moviepro have an active track function?
2017-12-16
PHL
Rmh1120 Posted at 2017-12-16 18:46
No, because it can’t directly control the Osmo. OTOH, if MoviePro can implement a BT mic feature, it should be doable in DJI Go as well,  but it isn’t. Not sure if there is an API other apps can use to control the Osmo, much like Litchi etc can control the DJI drones.
2017-12-16
Rmh1120
How about Apple AirPods? Anybody tried that?
2017-12-17
MCurtisMcCoy
This would make the Osmo Mobile 3 SO MUCH BETTER if we could Use a Bluetooth mic or headset for audio while using Active Track on the Osmo Mobile 3! - Still no solution yet?
Also, looking forward to being able to use active track with Facebook Live, YouTube Live, Skype Video Calls, Zoom Calls, IGTV, etc.
2020-1-9
