horcsab1967dron
Hungary
DroneLeg Posted at 2017-12-31 17:10
Thanks! What is your opinion of the following drone: Yuneec Typhoon H Drone
[view_image]
If you’re planning to go on flights that reach or exceed 1 mile, then the Typhoon H is not the ideal drone for you. Yes, you can add some directional antennas to the controller, but they will only get you to around 10,000 feet. That’s much farther than the stock antennas will do, but the Phantom 3 Pro and Phantom 4 will easily do 15,000 feet with no modifications at all. I’ve personally reached over 20,000 feet with the Phantom 4 in good conditions, and at those distances you’ll run out of battery before running out of range. You might never need to go 3 or 4 miles with your drone, but having that extra power means that you can also fly through and around structures and maintain a better signal. |
