CrystalSky & Spark Go 4 4.1.18
887 5 2017-12-17
Pierre Genin
Flight distance : 322 ft
I just update my CS550 to V02.04.06.00 with includes Go 4 4.1.18 and I have many problems with the Spark:
  • Only works at 2.4 Ghz. I can not change to 5.8 Ghz
  • RTH is grey and do not work on the Go 4 neither in the RC.
  • I can´t see the distance, altitude and speed of the spark in the Go 4.
  • The video signal fail more than ever.
I swich to an old phone with Go 4 4.1.15 and all the problems disappear.
How can I go back to Go 4 4.1.15 in the CS550?
Thank you,
2017-12-17
Wachtberger
Flight distance : 261509 ft
You seem to use an OTG cable. This unfortunately does not work with GO 4 version 4.1.18 and hopefully will be fixed soon. And even more unfortunately there is no way (that I am aware of) to go back to version 4.1.14 which was on CS before the update and has worked well. It is a highly deplorable situation indeed.
2017-12-18
lannes
Flight distance : 4465 ft
+1  with 4.1.18 use Spark with wi-fi it works as designed
2017-12-18
Pierre Genin
Wachtberger Posted at 2017-12-18 00:32
Thank you!
I hope that the offline maps that i have downloaded are still there, because I saw that they have removed that option from 4.1.18.
2017-12-18
Anthony566
Flight distance : 2488944 ft
The ONLY way to revert back to a previous version with the CS is to send it back to DJI it cannot be done by the user at the moment.
2017-12-18
Sjd666 1
Flight distance : 3785020 ft
I’ve just found this, dji telling people to connect a crystal sky to the spark remote via otg so it must be supported
2017-12-28
