PeteGould
rodger - I commented on this elsewhere but will put it here too for completeness.
There is ONE situation I see in which the controller could shut down due to firmware. Obviously I don't know the design and I don't have insider information, so this is conjecture. But it's just too suspicious that several controllers have all done this, and all of them seem to be after a recent firmware revision.
Consider: if your controller is on but your Inspire is not, sooner or later the controller will start beeping. Awhile after that, if there continues to be no connection, it will shut off.
In my view that means the firmware has a hook available to it to shut down the controller. The process of determining that there is no connection, sounding a repetitive beep signal, running a timer, and eventually shutting off the controller, are most likely accomplished under processor control as instructed by the firmware. If there is a BUG in the firmware, the same function that can be used to deactivate the controller after an interval of no connection could malfunction and shut it down instantly, connection or no. All it needs is an errant instruction due to a bug.
Just my $0.02. I haven't had it happen. But the idea that several people have all suddenly developed loose connections in their controllers after a firmware update isn't sitting quite right. |
