Blizzard
Flight distance : 173734 ft
Belgium
Just have to properly balance those props!.
Take a toothpick or a sate stick that fits in the center hole of your propeller and put it on the edge of two glasses.
If you spin it slowly it should be in balance in any position.
If one side is always ending down, it means that that side is heavier. With some sandpaper, remove a little bit from the backside until both sides are in balance.
If you have a scale that can measure milligram, weigh each propeller and see if there is any difference. This also will give vibrations?
