P mode and A mode
5484 6 2017-12-18
Prsmeds
Flight distance : 3711 ft
How do I switch between P mode and A mode? What mode should I use if I want to use the camera options like shallow focus and panorama?
2017-12-18
Enri
Flight distance : 683501 ft
Are you referring to p-gps mode and atti mode?...if yes you can't switch between them.
2017-12-18
Enri
Camera options are under manual settings in cam menu...
2017-12-18
Zbig
Flight distance : 7349 ft
Poland
If you mean "P" and "A" modes as traditionally found in still cameras (on the "PASM" selector switch or otherwise), please keep in mind the Spark's camera doesn't have physical variable aperture. It's more like a smartphone camera, with an "Auto" mode, "Auto with some user tweaks possible" and various panorama modes. While I'm not 100% sure there's any "shallow depth-of-focus" type mode available (not at home right now), if there is, it's purely software-simulated as there's simply no aperture to open wider or "stop down". That's also the reason behind the popularity of ND filters with this type of consumer drones as, in the absence of variable aperture, they enable you to let less light in and help you achieve these "cinematic effect" shutter speeds.
2017-12-18
Prsmeds
Zbig Posted at 2017-12-18 07:42
Ok, thanks for the help
2017-12-18
Enri
I completely mismatched....dammned acronyms ...  anyway shallowfocus is simulated with the drone going up and down instead of the aperture. That's just what I can add.
2017-12-18
DJI Elektra
Prsmeds Posted at 2017-12-18 07:45
Hi, sir. Please note that you can only set camera in A or M mode. And you can change the camera setting before enter panorama mode. Thanks for your help.
2017-12-18
