caddwizard
Flight distance : 453788780 ft
Have just been through the firmware update and unlike the previous one I had problems. Followed the firmware update guide (not the video as its not the same).
Failed to correctly update and essentially the bird was flightless. The usual dddd to d-dd was replaced with a myriad of different versions of sounds in pitch and speed.
Contacted DJI online support and they suggested formatting the SD and trying again. Did so but again no luck. Tried another SD, formatted it and ran the update again as per the manual (pdf). Did take nearly twenty minutes and went through an automatic restart which it again carried out a further update, I suspect it was for the gimbal as it was a lot more active this time. Another 8 ish minutes and d-dd was back with the rear light doing it bit.
Lesson here BE PATIENT
Controller was then updated via USB to the camera. All was AOK. Just required compass calibration.
A quick nervous test flight went a treat and loved the auto landing gear up on launch (at last).
I will say one thing make sure that your SD is formatted as exFAT not as NTFS as it will do nothing. Ps that wasn't my problem, believe it was the SD card.
Happy skies
