Signal too weak please adjust antenna Help!
10432 23 2017-12-18
Francescospark
Portugal
Hello!
Since 2 days ago, I was flying near a bridge and around 50m of distance, on my screen appeared this message:
Signal too weak, please adjust antenna. I tried but nothing happened (apparently the antennas are already adjusted).
No crashes or issues (drone and remote) since I flew last time (and everything was fine).
Well, I tried to fly in another location just today and it's doing the same thing. Downloaded the update but still same thing.
Before and even after the new update.
Any suggestions? What to do?
Please help!
2017-12-18
Bright Spark
Flight distance : 22129 ft
The antennae are not pre adjusted. They must be perpendicular the direction of the spark.
2017-12-18
Francescospark
Portugal
Yes I know, I already put thousand times the antennas in the right perpendicular position, but still continues with this issue.
2017-12-18
Bright Spark
How far could you reliably go before?  Minedrops out at 70 meters, depending on height, reflections, wet grass etc.
Sometimes I get better results with antennae facing a few degrees downwards, presumably the signal bounces along the ground.
But 100 yds is adequate for me  in general, though I would prefer it solid to say 150 yds. No way can I seee it further off.
2017-12-18
Francescospark
Portugal
Bright Spark Posted at 2017-12-18 11:25
Hello!
With remote just 70 meters?
Mine with remote used to go also around 350m distance..But since 2 days ago it has this kind of issue. It's really pis»»ng me off. At 50m distance or even less i start to see this message on my phone screen. Annoying.
2017-12-18
Bright Spark
Well used to get 300 meters with otg, which seems dead now.
I'm fed up with poor transmission too.
My ordinary aircraft radio does 1-2 km easy on 100mw power.
I don't want wires or any more faffing around.
2017-12-18
Francescospark
Portugal
Bright Spark Posted at 2017-12-18 12:23
Same here. Cable seems to be not working anymore, I really dunno what's going on with DJI. But the must solve this issue.
2017-12-18
Bright Spark
Six months in now, and no info of any sort.
I'd love to think DJI are lobbying for some criteria that enable easing of restrictions for very limited range models.
Too optimistic?
2017-12-18
DJI Elektra
Francescospark Posted at 2017-12-18 12:33
Hi, sir. Please ensure that you don't open bluetooth device, such as, apple watch. You can try to enter airplane mode and see if it gets better. Also, please check that if your drone is in the channel with best signal. Please keep us updated, thanks.
2017-12-18
Francescospark
Portugal
DJI Elektra Posted at 2017-12-18 20:33
This is something that I do always. Always flight mode with cable, and always putting antenna in the right way and always putting off bluetooth, watches etc. Channel is automatic and should be ok.
This issue comes with the update maybe, i really dunno but it's so annoying that everytime there is something wrong with this DJI drones.
But what's the connection between the message ''signal too low, please adjust antenna'' and the fact that otg doesnt work properly, lose the signal wihout a reason, it doesnt give you the % of the battery, etc, and the drone lose the Signal at 50m?
Really DJI suks, im so dissappointed. Any solution? the assistance is useless!
2017-12-19
DJI Elektra
Francescospark Posted at 2017-12-19 02:59
Sorry that you feel disappointed about our product. Please provide us the flight data and the black box for further analysis. We will try our best to solve your problem.
2017-12-19
deukyun512
Flight distance : 427677 ft
Iceland
I had the same issue with above user. I am very dissatisfied with this issue. Any resolutions?
2018-7-19
Alexey Batalov
Flight distance : 21105262 ft
Try downgrading your app to say 4.2.12 on apk mirror
2018-7-20
Yukon 3-0268
Flight distance : 1148 ft
https://www.amazon.com/RCstyle-P ... e+booster&psc=1
2018-7-20
Northwood
Flight distance : 2148596 ft
This is a little dated but still applies
2018-7-20
Anand Kumar6
Flight distance : 1010 ft
India
Sir same problem adjeast the antina week signal
Dji paintom 4 pro v2.0 please help mi how to fix this problem
2021-12-5
Anand Kumar6
India
Not fix my problem please help mi
Adjust the anitha no signal problem
2022-1-11
TWStories
Thanks for sharing this info.
2022-3-31
TWStories
Also if you are in urban environment compared to rural area.  The signal was sometimes terrible in an urban enviroment.
__________________________
Toronto Wedding Stories
Wedding Cinematography
www.torontoweddingstories.ca
2022-3-31
vladimirnesic
Flight distance : 2008 ft
Serbia
I have the same issue with my Mavic Mini. When I bought the drone, I could fly up to several hundred meters away, but after some time, I started getting an error message that the signal is too weak and that I need to adjust antennas. So far I've tried switching phones, updating firmware and fly database and I always turn off bluetooth and wifi. This issue is happening in completely rural environments where there are no possible sources of interference whatsoever. This is making my drone completely useless so much so that I rarely even bother to try to fly it. Due to this I honestly don't think I will be buying another DJI product ever again.
2022-6-24
Wolferl
Flight distance : 23793 ft
Austria
vladimirnesic Posted at 6-24 02:10
Hi Vladimir,
I do not own a Mavic Mini, but a Spark. The problem you described is most probably related to CE rules for RF emissions. In Europe (and many other countries with CE-like rules) RF gadgets can only emit a pretty tiny amount of RF power. In US, Canada (and others) there are FCC rules which allow for much more RF power so the possible flight distances are way bigger.
Of course, DJI advertizes distances under FCC rules, and even these are pretty optimistic with out-of-the-box drones.
A short google search shows that there are hacks available. Maybe this is of use for you (I have not tried it myself on a Mini).
Cheers & HTH,
Wolferl
2022-6-24
vladimirnesic
Serbia
Wolferl Posted at 6-24 06:47
Hi Vladimir,
Hi Wolferl,
Thank you so much for the tip, I'll definitely try it out.
I'm from Serbia, but I've been experiencing this issue while in Greece and Montenegro, so it definitely makes sense to be region (Europe) related.
The problem is that everything was working fine for few months and then it started throwing that error message all of the time.
2022-6-27
Wolferl
Austria
vladimirnesic Posted at 6-27 01:04
Hi Wolferl,
Hi Vladimir,
Have you got yourself some of these new fangled earpieces or a smartwatch lately?
You wrote you turned off Bluetooth on your cellphone, but did you also turn off any BT gadgets?
Cheers,
Wolferl
2022-6-27
vladimirnesic
Serbia
Wolferl Posted at 6-27 06:43
Hi Vladimir,
Hi Wolferl,
I do have a Samsung smartwatch, but I was taking it off when flying, but the issue persists.
2022-6-28
