Cetacean
Flight distance : 2528264 ft
Aloha allyssongemelli ,
The human eye has a "Flicker Rate" of 25 frames per second. This allows jerky video or film if the camera moves or rotates too fast. Since smooth camera movement is a desired trait, it makes sense to at least use 30 frames per second to get away from the "Flicker Rate". Anything higher than 30 FPS allows better slow motion so that decision should be based on clip or scene demands.
No matter what your FPS is, smooth camera movement ultimately determines the quality of your video. Obviously, it will be harder to make smooth camera movements at 25 FPS, so the videographer will have to be very talented. That is why you see so many videos with very little sideways camera movement or vertical rotation. Then you can also see the admiration viewers have for the talented ones with smooth rotations.
Hope this helps!
Aloha and Drone On! |
