DJI Diana
Flight distance : 2408 ft
djiuser_TaPbnCK Posted at 2017-12-18 14:20
I had the same problem after 5 flights...and NO crashes. Mine was a ribbon cable, but since it was so new I sent it in for repair. Big MISTAKE they said I needed to replace two cosmetic pieces of plastic because they had "marks" on them. When I asked how this would fix the gimball, I was told that if after replacing the plastic the Gimball did not work, tgey would then fix it. So I have to pay them 160 bucks for plastic, so I can actually get my warranty work done. Seems a little sketchy to me...bad customer service DJI. You tube has a ton of links to show how to fix it.
Hi sir, I am so sorry to read on this, could you please provide me with your case number so I can check what happened? |
