Can't get direct connect video through wired adapter to work
1379 12 2017-12-18
jmrfoto
Flight distance : 77257 ft
I have a brand new Osmo Pro kit, a brand new wired adapter, and a brand new CrystalSky Osmo mount... using my CrystalSky 5.5-inch monitor that I've had for a while.  No matter what I do, I have been unable to get the direct connect video to work to my CrystalSky.  I've spend hours so far working on this.  The WiFi connection works just fine but the direct wired connection just doesn't work.  I'v etried everything I can think of and I'm getting very frustrated with something that was just supposed to work as soon as I turned it on.
I need HELP please!
2017-12-18
jmrfoto
Just adding to my post... it just seems like there is no connection whatsoever between the CrystalSky monitor and the X5 camera.  All of the camera parameters as normally displayed on teh top of the screen are "N/A".
2017-12-18
jmrfoto
One more piece of additional information.... If I am operating with WiFi between the Osmo handle and teh X5, and I put the Osmo handle in sleep mode, when I power up the Osmo handle again the Wifi re-connects in a few seconds and everything is goo on WiFi.  BUT.. if I have the wired adapter plugged into the X5 adapter and I do this, the WiFi does not reconnect when I power up the Osmo handle from sleep mode.  So what if I wanted to use a Focus Handwheel with teh Osmo Pro and still use only WiFi?  This says that is impossible to do with the wired adapter in place.  Is this right?   I'm trying to pin down teh point of teh problem here so I know what to do, assuming that I am not making some setup error here.
2017-12-18
MenSch0r
Switzerland
I think, you have an old Firmware version installed. I had the same problem with the older Firmware version.
2017-12-18
jmrfoto
MenSch0r Posted at 2017-12-18 23:50
MenSchOr... are you talking about firmware in the Osmo handle or teh CrystalSky?  As far as I can tell they are both running the most recent version but I'l all ears   Thanks for your response
2017-12-19
MenSch0r
Switzerland
jmrfoto Posted at 2017-12-19 08:53
I talking about the firmware from the X5.
2017-12-19
Hi Jmrfoto, sorry for the trouble caused, can you see the image transmission when you connect Wired Video Adapter to Android mobile device?
2017-12-20
jmrfoto
DJI Mindy Posted at 2017-12-20 02:31
When I use a Samsung Galaxy Tablet I get teh exact same results.  The WiFi works just fine but the wired adapter connection results in a black screen and no camera connection at all.  Exactly the same results as with the CrystalSky
2017-12-20
jmrfoto
MenSch0r Posted at 2017-12-19 23:37
I have no idea how to update the X5 firmware... can you supply information?
2017-12-20
jmrfoto
PROBLEM SOLVED:  Taking the suggestion made I decided to try an X5 firmware update to solve the problem.  Found updated firmware at the link below and followed the update guidelines and teh problem is solved!  My wired video is now working....
2017-12-20
jmrfoto
jmrfoto Posted at 2017-12-20 14:34
Link where I found the firmware update.........
https://www.dji.com/osmo-pro-and ... te_search#downloads
2017-12-20
That is great to know, congrats, please let us know if there is further problem.
2017-12-21
MenSch0r
Switzerland
Great
Sorry for delay, christmas, you know
2017-12-27
